It is currently Fri 22. Nov 2024 5:28:34
 Post subject: Support for Ubuntu 20.04
PostPosted: Fri 01. May 2020 20:16:34
I recently upgraded my system to Ubuntu 20.04. Apparently, Ubuntu no longer provides Qt4, which makes it impossible to start the Spirit configuration software (3.0.0). (Qt4 was dropped from Debian: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=953294)
Code:
$ ./settings.sh
./settings-x86_64: error while loading shared libraries: libQtGui.so.4: cannot open shared object file: No such file or directory
$ ldd settings-x86_64        ✘
   linux-vdso.so.1 (0x00007ffed3bcb000)
   libQtGui.so.4 => not found
   libQtNetwork.so.4 => not found
   libQtCore.so.4 => not found
   libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f1a1bcb2000)
   libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f1a1bad1000)
   libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f1a1b982000)
   libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f1a1b965000)
   libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f1a1b773000)
   /lib64/ld-linux-x86-64.so.2 (0x00007f1a1bcec000)
PostPosted: Sat 02. May 2020 7:43:16
Thanks for the report.
It will be fixed very shortly for upcoming new 3.0 version.
PostPosted: Sun 27. Sep 2020 19:35:20
Hi guys, I installed qt4 on my ubuntu 20.04 and the tool works fine now. Found the instructions below:
https://askubuntu.com/questions/1234786 ... untu-20-04
PostPosted: Sun 27. Sep 2020 19:42:02
no need to install anything. Just start: settings.sh script and everything should work.
PostPosted: Sun 27. Sep 2020 20:30:29
I kept getting an error until I installed the qt4 libraries.. fairly fresh default installation from a couple of days ago. Any idea what else I could have been doing wrong?
PostPosted: Wed 21. Oct 2020 16:35:22
It works on my Ubuntu 20.04 installation. I had to install libaudio2, but nothing more. Qt4 is bundled with the Spirit software, so no PPA required.
PostPosted: Wed 21. Oct 2020 17:01:44
Thanks for the report. What error are you getting when starting the software?
Users browsing this forum: No registered users and 11 guests
