It is currently Sun 24. Nov 2024 19:55:43
 Post subject: udated ??????
PostPosted: Mon 20. Apr 2020 1:54:43
sorry Thomas, 30 was a bust.almost killed Helis. but things happen. Okay flashed back to 2.8 now everything was gone. would blind but no controls at all. So okay went throught wizard and old notes got everything okay??But my banks don't work and forward backward tilt of heli makes tail rotors move in stabilization. where is all the manuals for setting banks. DX8 with satilites. thks. :evil: Now it wont reopen in wizard at all.
 Post subject: Re: udated ??????
PostPosted: Mon 20. Apr 2020 15:34:40
it is enough to flash 2.8 firmware with no adjustments.
Maybe you were using incorrect method of flashing 1.3.2 and then 2.8.0 version. This could cause changes in the settings.
But changes in the Channels tab should fix it.
Do you have a backup settings made before flashing 3.0.0?
PostPosted: Mon 20. Apr 2020 21:32:20
I also tried to flash back from 3.0.0 on a Spirit II due to uneven rescue, even after leveling and resetting the accelerometers. After loading 2.8 I selected firmware update, and it said I needed to go back to 1.3.2 so I did that. Now it will not update to 2.8.0. Any way out? Thanks, Dan
After numerous tries it recovery flashed to 2.8.0. I loaded some banks, and reset my rudder end points because I got a warning that they were at 255. Then it said "not connected" and I have not been able to connect since. I had not got to the point of downgrading the GPS yet. Unit gives no pitch pump (init finshed) and has slow blinking blue light. ????
thanks
Synergy 516, 556 stretch, 696.
PostPosted: Tue 21. Apr 2020 7:10:51
Please do not update to 1.3.2. This firmware can't know any newer unit so it will brick it if you will do so.
For downgrading to 2.8 use always Spirit Settings 3.0.0.
Please contact me by a private message in case of a similar issues.
Users browsing this forum: 10x and 58 guests
