It is currently Sun 24. Nov 2024 19:58:13
PostPosted: Sat 18. Apr 2020 5:14:00
I tried to downgrade the firmware from V3 to V2.8 on one of my spirit pro units. It said the flash was successful. Upon powering the unit back on after the update, it is not responding to any transmitter inputs at all, and the servos are moving in strange ways on their own. One time I powered it on and one of the cyclic servos shot up and bound to the frame. In the diagnostic screen in the software the cyclic inputs are fluctuating on their own.
Something is very wrong with this unit now, I have no idea how to fix it.
PostPosted: Sat 18. Apr 2020 5:21:55
I just flashed it back to v3 and it is working again. That was scary. Is there a proper way to downgrade? Did I do something wrong?
PostPosted: Sat 18. Apr 2020 5:53:38
i had a pop saying i had to downgrade to 1.3.2 then back up to 2.8. luckily i saved my setup before i did anything, so it was mostly painless.
PostPosted: Sat 18. Apr 2020 5:59:36
How did you get a hold of that old version?
PostPosted: Sat 18. Apr 2020 6:11:42
it's sticky link at the top, but there was a link in the pop up
viewtopic.php?f=20&t=1236
PostPosted: Sat 18. Apr 2020 6:13:17
Nevermind I got it. All appears to be working on 2.8 now. That was freaky. I had originally downgraded to 2.8 using the V3 software- so a heads up to anyone - DON'T do that unless you want to see your unit do some weird stuff, use the 2.8 software.
PostPosted: Sat 18. Apr 2020 8:13:34
Interesting, in my case first try to flash firmware 2.8 using the 2.8 software failed (but I did not try again). Then I used the 3.0.1 software to flash 2.8 (since I currently was on 3.0.1) and the downgrade was successful. Then I did a full reconfiguration, just to be sure.
PostPosted: Sat 18. Apr 2020 15:28:45
You can downgrade with 3.0 version back to 2.8 without any issue.
Everything should be same as before.
Or you can wait week or so. Then everything will be tested and any issues sorted.
PostPosted: Sat 18. Apr 2020 20:21:59
I have no idea what happened then, but all seems to be working now.
Users browsing this forum: The Gasman and 57 guests
