ZeXx86 wrote:
we have solved the problems with firmware update.
All SRXL2 receivers should work now.
Please flash this firmware:
http://spirit-system.com/dl/fw//spirit-fw-2.8.1.4dfWiring diagram for AR6610T will be available tomorrow. For this receiver normal JETI Integration cable is needed (or you can make the cable at home).
Hi Tomas
I have tested the new firmware and there is some issues.
Its sems impossible to get throttle out to work,in diagnostik window(ch1)it moves from 0-100% but the esc is not responding.Iwent back to spm4649t just for testing and the esc starts up fine,whith the same settings
in unit (i only Changes recivertype).
And channel 7 bankswitching and 8 rescue dont respond(50%)at all in diagnostik window,same settings in tx DX9 as whith spm4649t.It sems that AR6610T only trasfer 6 channels.
Hope you can fix the problems or tell me if i doing something wrong.
Everything else works perfekt.
//Lars
