It is currently Fri 22. Nov 2024 12:02:50
Post new topic Reply to topic  [ 112 posts ]  Go to page 1, 2, 3, 4, 5 ... 12  Next
 Post subject: [SOLVED] srxl2 AR6610T
PostPosted: Thu 27. Feb 2020 16:08:09
Hi serius problems
I have install the new AR6610T in my Kraken(Spirit pro)using the Jeti cable.And the unit dont show any respons at all on stick input.I have folow the manual and set the unit rx to srxl2 plug in yellow Cable in ail pin +- in rud portit is the same as SPM4649T,the other end in rx markt bind/prog/srxl2 yellow Cable in the pin markt whit an
S.I Think Every cable is connected right.i have tested the rx by plug in servos in different ports it works fine.
i have install airware 2.05 in tx 2.8.0 in spirit.The led on unit is solid the log says good helth.
IN diagnostic page all channels show 0 or 50%.
PLeas help?
//Lars
 Post subject: Re: srxl2 AR6610T
PostPosted: Thu 27. Feb 2020 18:15:45
you sure is connected properly ?
http://manual.spirit-system.com/index.p ... trum_SRXL2
PostPosted: Thu 27. Feb 2020 22:32:38
hi
Any other solution to Connection?
PostPosted: Fri 28. Feb 2020 4:57:28
It looks like you have something in the sat port. What cable is that? If it’s a regular sat you can’t use it. If it’s a srxl2 sat then it should be plugged into the AR6610T.
From the receiver port
Orange should go to Ail pin
Red + should go to + on rud port
Brown - should go to - on rud port
This the same for the Spirit Pro
PostPosted: Fri 28. Feb 2020 5:57:01
In The satport is esc telemetry connected,The red cable going to pitch pin is The rpm from esc.
I have no sat connected nor unit or ar6610t.
And The orange cable from rx going to ail pin on unit and +- from rud port on unit to rx.
I used The spm4649t and one sat before,it works perfekt. I guess i have to go back to that combo
//Lars
PostPosted: Fri 28. Feb 2020 10:57:12
we will receive AR6610T receiver within 2 days, then we can prepare all instructions for connection and setup.
PostPosted: Fri 28. Feb 2020 11:44:45
OK
Wee have a helimeet tomorrow so i have going back to spm4649t,looking forward that you can solve
the problems Tomas.
//Lars
PostPosted: Fri 28. Feb 2020 13:21:31
I was going to set mine up today. Glad I waited and checked this out. Thanks.
PostPosted: Tue 03. Mar 2020 2:06:21
Any update on the AR6610T setup and programming?
Thanks for the hard work on this.
PostPosted: Fri 06. Mar 2020 3:29:12
I'm interested in this as well. I just received my Spirit 2 and am still deciding on receiver/sat. It would be nice to know definitively if the AR6610T is a valid option.
Users browsing this forum: Bing [Bot] and 22 guests
