It is currently Sun 24. Nov 2024 21:18:29
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
 Post subject: Rescue question?
PostPosted: Sun 16. Feb 2020 20:00:12
In normal rescue mode, when I hit rescue when the heli is inverted, it does not climb out but merely hovers at the same altitude before recovering. I find this to be rather nerve wrecking when I initiate recovery close to the ground as it seems about to slam into the ground when it flips / loops upright. Therefore, a good climbout before recovery will be safer.
How do I set inverted climb out to a higher altitude before it recovers right side up?
 Post subject: Re: Rescue question?
PostPosted: Mon 17. Feb 2020 10:39:29
the problem might be very likely in the swashplate settings.
It is important that when you enter Servovs/Subtrim (tunjing) menu all servos will be at the center and at the same time swashplate is leveled and at the same time there is 0° between main blades. Could you verify this is true?
PostPosted: Mon 17. Feb 2020 13:30:04
Check your Acro Delay setting in the Stabi menu. By increasing this setting the model will climb longer before the flip to upright.
PostPosted: Mon 17. Feb 2020 13:33:46
Yes, in order so that heli will ascend first set Acro Delay. This will ensure helicopter will climb and then flip and then climb again.
PostPosted: Mon 17. Feb 2020 17:36:58
Just double checked. All servos already centered, swash levelled, blades @ 0°
My rescue settings are here:
https://ibb.co/StLjMWS
PostPosted: Mon 17. Feb 2020 17:43:29
Yes I have. I set it to 1 sec. When I hit rescue, it merely hovers inverted for 1 sec before flipping upright.
PostPosted: Mon 17. Feb 2020 20:58:16
Verify its 1s and not .1s also what is your Rescue Collective setting ?
PostPosted: Mon 17. Feb 2020 22:05:19
Can you attach a pitch gauge (blades out to the side, not in line with the boom), check that collective pitch is zero at mid stick,
Check +- pitch is equal at max / min stick. What is max / min pitch at max/min stick?
Check pitch is zero at mid stick in the diagnostic tab.
Check servo travel is zero at max/min stick in servo->servo travel correction->setup.
Check Limits(tab)->collective pitch is a sensible value (e.g. 160 - 180)
Then set the mid stick and the pitch gauge will be zero.
Hit rescue - What is the collective pitch on the pitch gauge with rescue enabled?
Upload your 4ds setting file as an attachment to your post on this forum.
PostPosted: Tue 18. Feb 2020 22:50:20
Yes. Collective pitch is zero at mid stick with blades out to the sides.
Yes, both max and min equal +12° - 12°
Yes. Pitch is zero.
Yes. Servo travel is at zero.
about 100-120
Done.
About 10.5°
Attached
19 Feb 2020 -.4ds [255 Bytes]
Downloaded 32 times
PostPosted: Wed 19. Feb 2020 14:05:01
Cyclic ring looks low at 5 degrees, what heli is it?
Don't think that would affect a rescue climb though? Try increasing this to 9-10 degrees, make sure the servos are not binding at max/min pitch as you adjust it.
Also, in a skids down hover, hit rescue. Does it climb?
You've measured 10.5 degrees of positive pitch in rescue, so it should be very capable of climbing, unless your motor slows down/boggs out significantly etc at the same time?
Quote:
Stabi -> Rescue collective pitch 47% (0% <-> -10%)
I'm hoping that's a bug in the 4ds viewer, maybe someone from spirit can comment on that....
You measured +10.5 in rescue out of +12 so that's about 88%, as you stated it was 80% so I think the 4ds viewer is wrong.
Quote:
Servo Travel Correction
Servo Travel Correction -> Pitch (CH1) -> Maximum 14 (-64 <-> 64)
Servo Travel Correction -> Elevator (CH2) -> Maximum 4 (-64 <-> 64)
Servo Travel Correction -> Aileron (CH3) -> Maximum 2 (-64 <-> 64)
Servo Travel Correction -> Pitch (CH1) -> Minimum -5 (64 <-> -64)
Servo Travel Correction -> Elevator (CH2) -> Minimum -30 (64 <-> -64)
Servo Travel Correction -> Aileron (CH3) -> Minimum -5 (64 <-> -64)
Can you get these to closer to zero by adjusting the link lengths with a swash leveller, are they required? That's quite a lot of correction.
Users browsing this forum: No registered users and 14 guests
