It is currently Fri 22. Nov 2024 11:50:16
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: SRXL2 Technology
PostPosted: Thu 23. Jan 2020 18:31:52
Hello Tomas
Thanks for this, will try at the weekend...
PostPosted: Sat 25. Jan 2020 23:20:15
Hello Tomas
I see from the new software that there now is a srlx2 in the receiver section. If i have the spm4651t and 2 sats do i now pick srlx2 in the menu.
Before with the spm4649t i had to pick dsmx...
Regards Adrian...
PostPosted: Sun 26. Jan 2020 8:46:56
SPM4649T does not support SRXL2 so everything is same here.
PostPosted: Sun 26. Jan 2020 19:02:52
Hello Tomas
I want to put in a SPM4651t with 2 dsmx sats. If i choose SRLX2 for the SPM4651T, will the 2 dmsx sats still work? this is on a Spirit Pro...
Regards Adrian
PostPosted: Sun 26. Jan 2020 19:28:07
No, DSM2/X satellites and SRXL2 receiver will not work together. You have to get SRXL2 receiver and SRXL2 satellite.
PostPosted: Sun 26. Jan 2020 19:41:00
Thanks for this Tomas..As there are no SRXL2 sats available at the moment i will wait untill normal DSMX sats can be used...
Regards Adrian
 Post subject: Re: SRXL2 Sats
PostPosted: Tue 28. Jan 2020 1:23:26
The SRXL2 remote receiver (SAT) link below.
Available late March
No external antenna wires!
https://www.horizonhobby.com/dsmx-srxl2 ... er-spm9747
Will these 4wire sats use an adapter to work with the sat port or use an adapter to connect to the main connector pins?
PostPosted: Tue 28. Jan 2020 8:51:20
These receivers can't be used with satellite ports. There will be adapter which will be connected at the AIL/RUD port.
This adapter will be available for sale likely this week in our eshop.
PostPosted: Tue 28. Jan 2020 10:08:44
Can the 4651T be compined with DSMX sat ? , as this is possible with brain2 and even the new Spektrum FBL unit
Skickat från min SM-G950F via Tapatalk
PostPosted: Wed 29. Jan 2020 23:06:52
Will the sRLX2 receiver and SRLX2 satellites be connected to the same port through the Spektrum Multi adapter?
