It is currently Sun 24. Nov 2024 21:52:16
 Post subject: [SOLVED] 4dsviewer
PostPosted: Thu 12. Dec 2019 20:19:54
Hi Tomáš, will there be an update to the 4dsviewer for the latest firmware version 2.7.1? I know you have other higher priorities. Keep up the good work.
 Post subject: Re: 4dsviewer
PostPosted: Thu 12. Dec 2019 21:18:46
it will be updated as always. There is no reason to not update it :)
PostPosted: Mon 16. Dec 2019 18:07:14
Hi Tomas,
Is there a new link for profile viewer as the link in the settings tab does not work with 2.7.1 profiles, only 2.6.4 and older. Thanks in advance.
Best regards,
Kevin
Blade 230 S / 230 S NF / 450X / 500X / 550X ~ Trex 470LM ~ OXY 3-285 / OXY 4-325 / OXY 4 MAX ~ Spektrum DX9 BE / DX6 Gen 2 ~ Spirit FBL
_______________________________________________
Team OXY Helicopter - Lynx Heli Innovations Field Rep
PostPosted: Sun 22. Dec 2019 16:19:19
Tomas,
When can we expect a new viewer update to be available?
Best regards,
Kevin
PostPosted: Sat 28. Dec 2019 18:39:16
+1
Just setting up a heli and would like to use the viewer for 2.7.1
PostPosted: Thu 23. Jan 2020 23:55:43
Still no updated viewer :(
PostPosted: Fri 24. Jan 2020 9:16:10
it should already work.
PostPosted: Fri 24. Jan 2020 9:19:28
It doesn't for 2.7.1 last time I tried it.
PostPosted: Fri 24. Jan 2020 9:27:53
You can try again :)
 Post subject: Re: [SOLVED] 4dsviewer
PostPosted: Fri 24. Jan 2020 13:38:22
It looks like "Stabi -> Rescue collective pitch" is not being displayed correctly for a 2.7.1 4DS file.
Users browsing this forum: Bing [Bot] and 38 guests
