It is currently Sun 24. Nov 2024 23:48:48
PostPosted: Fri 10. Jan 2020 1:52:03
I go to "General / Cannels" I assign "F:Stabi Function" to 8" then I go
to "Stabi tab" and set Stabalistion (Normal)
In my DX9 I assign Aux3 = Channel 8 then I assign channel 8 to switch (G).
I can see in the Diagnostic tab "Stabi on and off with my switch.
This will give me when the switch is on Stbai in normal mode.
I do not use bank switching so this would all be in bank 0.
Do I understand this right ?
WCP
PostPosted: Sat 11. Jan 2020 19:15:35
yes, you are right.
If you can see it is acting in the Diagnostic tab it will work properly.
PostPosted: Sat 11. Jan 2020 19:45:23
Thanks ! Can I tell if Sabi is on by looking at the heli and moving it around ?
What might notice different with Stabi on and off ?
WCP
PostPosted: Sat 11. Jan 2020 19:48:19
You will see it in the Diagnostic tab as Engaged.
It is possible to distinguish behavior of the swashplate, behavior is little bit different. Always return to the center.
Users browsing this forum: tomsl and 48 guests
