It is currently Sun 24. Nov 2024 21:35:10
PostPosted: Sat 28. Dec 2019 21:18:02
I've just updated my spirit to 2.7.1 and the windows software to the same. I've connected via usb and changed settings etc all fine.
I've updated the wifi module to "wifi-link-2.7.0-win32.exe" successfully (shown in the updater)
I cannot connect via wifi to the spirit with the windows software.
I cannot connect via wifi with the android app (build 5.12.2019-release). The app crashes and closes as soon as I click connect.
Has anyone managed to connect with the latest wifi module version?
PostPosted: Sat 04. Jan 2020 11:38:52
Does anyone else have a wifi and android module that can try this with the latest firmware?
There are 2 posts about this on the forum now. Want to make sure it's not my phone that's the issue. Android 9
PostPosted: Sat 04. Jan 2020 17:57:43
We are testing it but cant replicatd the problem.
It is working well with Android app and Windows app for us.
Please try to backup your settings and then use a factory settings of the unit.
What will happen?
Likely there is some parameter in your settings that was configured improperly. In this way you will find if this is the case.
After test you can load your settings back.
PostPosted: Sat 04. Jan 2020 19:10:25
Using a laptop I can connect to and change settings with the wifi module and web browser. Spirit windows application doesn't detect wifi module, only usb.
I cannot connect with the android app.
The app crashes when connecting.
I have restored factory defaults (with usb dongle)
It still cannot connect with android app and wifi. Reinstalled spirit app. Still crashes when connecting.
PostPosted: Sat 04. Jan 2020 21:53:41
For Spirit Settings on Windows you have to set correct IP address with CTRL+W.
Only then it will detect Wifi-Link.
PostPosted: Sun 05. Jan 2020 13:00:27
Ok I'll try that.
But please fix the android app. Whatever changed in the last update seems to have broken it.
PostPosted: Sun 05. Jan 2020 21:01:41
We have report that the app is working, but not with the latest Android. So the issue is because of changes in the system. We have to find what they changed.
PostPosted: Mon 06. Jan 2020 13:30:21
We have added support for Android 9.
App will be available within few hours for download from Google Play or you can download directly here:
http://spirit-system.com/dl/settings/se ... -2.7.1.apk
PostPosted: Fri 24. Jan 2020 9:22:37
All working. Thank you for your support!
