It is currently Sun 24. Nov 2024 23:39:52
PostPosted: Thu 26. Dec 2019 11:53:23
Hi, and Merry Christmas.
I received a micro Spirit for Christmas that I plan to use with a HW 25 Platinum ESC, I have bought the Telemetry cable and will be running into an FRSky R-XSR receiver (I have a similar set-up using an original Spirit and a HW 50 on my 450).
A couple of questions - when I run the Telemetry into the SAT port and the ESC / BEC into the AUX port this will give me two 6V feeds (as the ESC also outputs the selected voltage through the Telemetry port - at least it does on it's bigger brothers) - will having two 6v feeds be an issue?? If it is, should I use the feed on the Telemetry port (bigger connectors) or the ESC / BEC feed???
Thanks,
Mike.
PostPosted: Thu 26. Dec 2019 12:39:59
Telem UNI is designed to not feed any voltage to the SAT port. Otherwise this would destroy the unit.
Any way telemetry port is not recommended for powering. So if you are using wiring described in the manual there will be no issue.
PostPosted: Thu 26. Dec 2019 12:51:40
OK - so I just disconnect the Positive wire on the Telem port - thanks for the quick answer
I'll re-read the manual before preceeding
PostPosted: Sat 28. Dec 2019 8:39:16
Tomas - another question I'm afraid - I really don't want to damage my micro Spirit
If I connect the integration cable leaving the red lead connected to my R-XSR, will this cause a problem - with this put power through the Integration cable into the SYS port??
Thanks,
Mike
PostPosted: Sat 28. Dec 2019 10:40:37
the FrSky integration cable will not feed any voltage to the unit. The red cable from side of the receiver is used only for powering the electronics inside. But red cable from side of the unit is for communication purposes.
So with this cable you do not have to worry. The red cables must be connected from both sides in this case.
PostPosted: Sat 28. Dec 2019 11:15:58
Excellent - thanks for explaining
Users browsing this forum: No registered users and 47 guests
