Hi
I just replaced my MicroBeast by a Spirit unit on my Trex500, and I'm struggling with configuration.
Hardware:
TX: Multiplex Profi 16, Firmware 3.56 (RF firmware version: 1.72)
RX: Multiplex RX-7 MLINK, Firmware 1.38, SRXL V1 output activated
Flybarless controler Sprit V2 Firmware 2.6.4
Installation: horizontal 0°
Head configuration : CCPM 120°
Servo connections CH1,CH2,CH3 triple checked
On the transmitter all mixers are disabled, and all channels output a linear (-100..+100%) signal. I checked with the transmitter integrated servo monitor. But on the Spirit side, channel readings are a bit weird. TX channel 4 seems to be skipped, TX channel 5 is mapped on spirit channel 4, TX channel 6 is mapped on Spirit channel 6. Elevator (collective) is reversed with very limited range is 118..0%, Pitch channel is reversed with limited range 118..-68%, see table bellow
Code:
TX channel | Spirit channel | mapping | status / range
1 1 Aileron ok, -107..+107%
2 2 Elevator (collective) reversed 118..0%
3 3 Rudder ok, -107..+107%
4 ignored
5 4 Gyro ok , -92..95%
6 5 Pitch reversed 118..-68%
Actually the Pitch and Elevator (collective) signal range seen by the spirit unit seems to depend on the Collective position on the TX when the model is powered up:
Code:
TX Collective initial | Spirit Elevator | Spirit Pitch
position at power up | (collective)range | range
-100% 0..-118 74..-118
0% 108..-106 109..-104
+100% 118.. 0 118.. -68
After setup, all axis are moving in the right way. When moving the model, aileron and rudder are properly compensated but:
- Collective is slow to respond
- When moving the model on the pitch axis, the unit respond by adjusting collective (!?)
Am I missing something ? Was the Sprit V2 tested with Multiplex gear ?
A worried customer.
