It is currently Mon 25. Nov 2024 0:48:58
PostPosted: Mon 28. Oct 2019 6:40:46
Spirit 2
R-XSR via SBUS
FrSky Horus X10S OpenTX 2.2.4 (I think)
Hobbywing 60A V4
I am unable to get any ESC telemetry data on my Horus X10S even after trying Discover New Sensors. But I do get telemetry of my FrSky S-Port mini voltage LiPo cell sensor so something seems to be working.
I also cannot get integration working. I have integration working with Lua on my other Spirit setups, so I know my TX is set up correctly for that.
Under Telemetry Settings in Spirit setup I have selected Hobbywing V4.
I have a direct connection from my HW 60A programming port to my Spirit 2’s SAT 1 port, but with the red power wire removed. I am not using a telemetry UNI cable. I’ve done this on Spirit 1 and uSpirit no problem (direct connection with red wire removed). I don’t think this is the issue because integration isn’t working either.
Also tried the SAT 2 port of the Spirit 2 but that didn’t work.
I have the FrSky integration cable between the SYS port of the Spirit 2 and the S-Port of my R-XSR. The longer side of the integration cable goes to the SYS port.
Any ideas on what to try next??
Find me on HeliFreak, username Xoexoe
PostPosted: Mon 28. Oct 2019 7:15:07
Ugh Nevermind. Figured it out. User error.
My integration cable was not actually connected as I described it above. It was backward.
PostPosted: Tue 29. Oct 2019 15:36:34
Great, thank you for the message!
Users browsing this forum: No registered users and 87 guests
