It is currently Mon 25. Nov 2024 0:55:08
[ 3 posts ] |
xoexoe
Posted: Mon 21. Oct 2019 22:02:55 |
I am using 3 different Spirit units: • Spirit Black with R-XSR receiver • micro Spirit with XSR receiver • Spirit 2 with R-XSR receiver
All have integration and telemetry enabled via FrSky Horus OpenTX. All have a FrSky integration cable connected between the SYS port and the receiver's S.Port.
If I want to connect the USB programming interface connector to my units (because I'd rather do some particular setup using computer than using integration), I need to access the SYS port. But the SYS port is occupied with integration cables.
Here's my question: Is it safe electronically for me to make a simple Y-connector so that during setup on my computer I simultaneously have the SYS port connected to my computer's USB drive and keep the FrSky integration cable connected to the SYS port? Usually I physically disconnect the FrSKy integration cable when I want to connect to a computer, but I'm wondering if it's safe to just keep it connected. If I do so then the USB programming cable would be in parallel with the FrSky integration cable and with all S.Port sensors.
I would be powering the unit with my HobbyWing bulit-in ESC via Aux or Aux 1 port.
_________________ Find me on HeliFreak, username Xoexoe
xoexoe
Posted: Fri 25. Oct 2019 6:20:26 |
Is this safe?
Posted: Fri 25. Oct 2019 7:10:28 |
it is not safe unfortunately and also it will not work when connected at the same time.
[ 3 posts ] |
Users browsing this forum: No registered users and 61 guests |
