It is currently Mon 25. Nov 2024 2:58:47
 Post subject: Heli is not responding
PostPosted: Thu 26. Sep 2019 2:45:15
When my 360 was stock, everything worked
When I dove into setting up a Spirit on this helo, some things worked, including throttle/CP
Now, I’ve copied and downloaded an RC Grouper's Spirit file and Spek file, and now no thr/CP or cyclic
On my Spek's monitor, thr/CP are sending the signal as well as cyclic, so it must be something on the Spirit's end or??? Also, it’s bound.
Can anyone give me a place to start looking pls?
PostPosted: Thu 26. Sep 2019 2:46:05
Heli is getting power, is bound, in my hand is responding as far as the gyro goes (swash and rudder servo)
Tx is sending signals to all servos
Heli just doesn’t seem to initialize, doesn’t throttle, servos don’t respond (when I give stock input)
PostPosted: Thu 26. Sep 2019 12:24:39
can you verify if Status LED is displaying any activity upon powering?
It should pulsate slowly and then stay On after initialization.
PostPosted: Thu 26. Sep 2019 20:01:07
Yes, it does a very slow pulse, and stays on and the swash dances a little.
But no stick input
PostPosted: Thu 26. Sep 2019 21:07:01
Then the problem is just in a wrong Receiver type settings.
Sadly you have not stated what receiver or radio you are using, so it is hard to help more.
Can you verify that when you will open the General tab there is receiver type that you are using right after initialization?
PostPosted: Sat 28. Sep 2019 3:06:56
Sorry for my minimal info
Good news, I figured it out.
My friend's settings I used included a GEOLINK. I’m not using a GEOLINK, so I just needed to un deselect that box.
Finished setup today, performed hover check, ALL GOOD!!!
Thx!
Users browsing this forum: No registered users and 89 guests
