It is currently Mon 25. Nov 2024 3:12:18
PostPosted: Tue 17. Sep 2019 8:26:40
Hello, I need help.
I sent the Spirit, - and the Geo-Link.
In addition, I bought the SPM 4649T.
As a remote control transmitter, the DX9.
Unfortunately, I now have big problems with the connections and setting up the switches.
When inserting the cables of the SPM4649T I prove the Rudd slot and
ELE / PIT / AIL Slot
Where, for example, will the cable of the Rudder servo and where the BEC power supply
plugged in?
I do not want to use slots as much as possible, because I use these for the functions
Geo link needed.
Can someone of you who also has the Spektrum DX9 as a sender, his assignment of the slots in the spirit and his switch settings with the Geo link?
Please help
Thank you Börni1
PostPosted: Tue 17. Sep 2019 8:31:29
GeoLink should be connected at the satellite port.
SPM4649T at the AIL and RUD port according Spektrum integration guide - through Jeti integration cable.
ESC/throttle cable should be connected at the AUX1 port.
BEC cable can be connected at the AUX2 and/or CH0 port.
That is all you have to connect.
PostPosted: Tue 17. Sep 2019 8:40:39
Hello ZeXx86
Thanks for your quick reply.
I meant Spirit Pro.
How should the ESC cable still be connected to the RUD port? :?:
Börni1
PostPosted: Tue 17. Sep 2019 11:01:29
I am sorry, this was mistake. Throttle cable should be connected always at the AUX1 port as described in our manual / Wiring section.
Users browsing this forum: No registered users and 70 guests
