It is currently Mon 25. Nov 2024 2:56:35
 Post subject: Home spot.
PostPosted: Fri 30. Aug 2019 0:11:28
I bought a Spirit Pro gyro and Geolink unit, and I got it beginning of this week.
I instaled the gyro first, and set it up without errors.
After that, I connected Geolink and do a setup.
I use a separate channel with 3-way switch to activate "Return to home".
Now to my question.
When I have the gyro connected to my computer, I can set a new home spot, the LED goes out, and lights up again.
But when the gyro is not connected to my computer, and tries to create a new home spot, the LED does not go out.
Do you have some ideas?
I use a Futaba T8J transmitter, and I use S-Bus connection.
Leif
Sweden
 Post subject: Re: Home spot.
PostPosted: Fri 30. Aug 2019 7:43:45
this might be caused because GeoLink has no signal or signal is poor.
Are you trying to program it outside at the field?
PostPosted: Fri 30. Aug 2019 9:23:45
Hi.
I have tried both inside and out.
I've been waiting for the blue LED to come on before I set another point.
The strange thing is that it works when I'm connected to the computer, but not when I disconnect the USB connection.
Leif
PostPosted: Fri 30. Aug 2019 10:39:15
You can use the USB cable go into Geo Link Aid tab and watch to see if the RTH say Programming when you flip the switch. This will tell you if your TX is configured correctly.
PostPosted: Fri 30. Aug 2019 12:04:17
Have also looked at this, and it is as it should.
Have tested now again, connected to computer, and without internet connection. I can create a new point. Removes the USB cable, and even now I can create a new point. Removes the battery, and reconnects. Waiting for the blue LED to come on, but now it's impossible to create any point ....
What this is because I have no idea. Can only create points if the gyro is connected to the computer, or has been.
But if I restart the gyro without connection to the computer, it will not work ...
PostPosted: Fri 30. Aug 2019 18:28:18
If you want to set a home point using the USB you must have an internet connection for the Map to work.
If your setting it with the Radio it must be programmed to send either -50 or -100 on the RTH channel. -50 sets the Home Point in the current bank, -100 sets the same point in all 3 banks at the same time
Are you watching the LED on the Spirit and not the Blue LED on the Geo Link.
PostPosted: Fri 30. Aug 2019 19:44:51
I look at the LED on the gyro.
I just want to put the point from my transmitter, but it only works when the gyro is connected to the computer.
PostPosted: Fri 30. Aug 2019 23:09:36
Have your verified the settings in the TX as I suggested ?
PostPosted: Sat 31. Aug 2019 8:24:58
Yes, I have. All looks good if I understand right. As I wrote before, everything works when I have
the USB-interface connected to the computer, but not when the USB-interface is disconnected.
Leif
File comment: Pictures from software.
PostPosted: Sun 01. Sep 2019 13:22:33
Do you get the swashplate bump when programming ?
Users browsing this forum: No registered users and 83 guests
