It is currently Mon 25. Nov 2024 3:10:08
 Post subject: Drift in altitude hold
PostPosted: Mon 10. Jun 2019 20:53:34
I've got the Geolink pretty well dialed in. The only thing I'd like to improve if possible is the altitude hold. I have position and altitude set to activate on the same switch. When activated the heli appears to hold it's horizontal position very well but the vertical position appears to ping pong up and down between what appears to be a 2' box. Can this be tuned out or is it the best I'm likely to get?
PostPosted: Thu 01. Aug 2019 15:25:17
this behavior can be configured with Vertical Correction Gain. Please try to decrease the value by 20 points and then try carefully again.
Users browsing this forum: No registered users and 62 guests
