It is currently Mon 25. Nov 2024 2:59:41
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed 11. Jul 2018 12:46:29
Thank you for the video. Yes, indeed it is wrong behavior.
Could you please send also your current settings?
Please check if your Throttle channel is assigned in the Channels window (usually to Channel 1). Because if it is not assigned, then unit can't know when main rotor is spinning. Instead it is verifying by vibration level and stick movement (whether the model is flying) but this is usually not fast enough.
PostPosted: Wed 11. Jul 2018 17:39:46
throttle is on channel 1
thank you for helping.
130.4ds [255 Bytes]
Downloaded 44 times
PostPosted: Fri 13. Jul 2018 20:05:10
i've made a sticky mix on my taranis, to pump in some quick rudder for the time being.
Gonna test that out tonight.
PostPosted: Sun 15. Jul 2018 15:49:02
Thank you for the details.
I can't find anything wrong.
But if you still can't make it work I can provide you a new firmware/software which should help, also regarding performance.
PostPosted: Tue 17. Jul 2018 15:30:50
a new firmware would be great, thank you
PostPosted: Tue 24. Jul 2018 7:22:41
We have sent email to you with the details.
Thank you for your patience!
PostPosted: Sun 21. Jul 2019 11:30:25
Any results / solution on this topic ?
I also have planned to use BLheli ESC on 130S tail
PostPosted: Mon 22. Jul 2019 7:22:53
As far as we know there is no issue. You can calibrate the Rudder ESC throttle range in the Limits tab now.
PostPosted: Mon 22. Jul 2019 7:39:40
THX - I'll do some more test on this.
Do you have a guide to link "Throttle Hold" to the tail motor output as well.
When I looked into the SW - I was not able to identify the right channel to link.
But as usual, once set - nobody does the proper documentation.
The hint you have to do it "there" is not sufficient - and a screenshot for the proper setting can ease up my life ;-)
Support is highly appreciated - THX
PostPosted: Tue 23. Jul 2019 14:21:18
I am having the same problem, the rudder motor will not start when the main motor spools up. It does start when I move the Rudder stick.
I have calibrated the Rudder limits as per your instructions. My low setting is 98, and my high setting is 150.
Is it mandatory to have an RPM sensor wired? For simplicity and minimum weight I was planning to just use a throttle curve instead of using the governor, because it is only a 120 size micro.
Users browsing this forum: No registered users and 88 guests
