It is currently Mon 25. Nov 2024 5:49:31
 Post subject: SBUS, S Port @ 7.4V
PostPosted: Thu 18. Jul 2019 15:24:33
I'm building up a heli with 7.4V servos. I plan to use an Frsky receiver (R4XR or R-XSR).
I'm planing to use a Spirit (non pro) with the SBUS inverter cable and S Port integration cable sold on the spirit website.
If I don't do anything special, these integration cables will have 7.4V on VDD. Is this a supported setup?
 Post subject: Re: SBUS, S Port @ 7.4V
PostPosted: Fri 19. Jul 2019 10:37:28
As far as I know is the signal voltage much lower than the power settings for your HV heli. So it should be supported.
Best Regards, Eugen
PostPosted: Fri 19. Jul 2019 12:11:19
Yes, without any problem.
I highly recommmend to not use R-XSR or similar small receivers for other than micro models.
Receivers with a standard servo connectors will be much better.
PostPosted: Fri 19. Jul 2019 15:10:27
Thank you.
Users browsing this forum: No registered users and 52 guests
