It is currently Thu 03. Apr 2025 7:29:53
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
PostPosted: Tue 03. Oct 2017 11:04:27
Online
Connection for Integration and Telemetry.
See the OpenTX integration guide for more info:
http://manual.spirit-system.com/index.p ... ntegration
PostPosted: Fri 21. Jun 2019 20:49:57
Looks like I would need some type of Y-cable to make this work, but the picture on the purchase website only shows a regular two-sided cable. If I select the µSpirit version of the FrSky Integration cable, will it come with the y-harness thing?
Here is the picture I'm talking about:
How would I make connections from the 4 pins of the XSR to the two separate 3x1 housings of the µSpirit unit?
Also, the diagram in post #1 here should be in the Wiki manual! Seems important.
Find me on HeliFreak, username Xoexoe
PostPosted: Mon 24. Jun 2019 7:30:57
Online
You have to solder the cables together. It is recommended only for experienced pilots.
PostPosted: Tue 25. Jun 2019 7:24:11
Thanks. Makes sense.
Also, is it possible to create my own FrSky integration cable? Can I just connect the correct pins together with a direct wire or are there electronics/logic/resistors/etc under the heat shrink?
PostPosted: Tue 02. Jul 2019 8:44:44
Online
No, you can't create own. It contain electronics.
PostPosted: Sun 14. Jul 2019 17:57:54
Cut the plug off the sbus cable and solder it to the xsr.
PostPosted: Wed 17. Jul 2019 17:34:00
Online
S-Bus Adapter and FrSky integration cable are very different inside. So you can't swap each other even if end plugs are same.
PostPosted: Wed 17. Jul 2019 19:24:36
Whoops my bad!
Any plans for f.port support? Sbus and telemetry on one pin!
PostPosted: Thu 26. Dec 2019 12:25:31
See below - my mistake
PostPosted: Thu 26. Dec 2019 12:34:53
Sorry - ended up answering the wrong thread :(
Users browsing this forum: ZeXx86 and 8 guests
