It is currently Mon 25. Nov 2024 4:46:10
PostPosted: Mon 24. Jun 2019 16:51:37
Hello everyone,
my heli pulls to the right and back when stabilisation (scale) is activated.
It is ok if stabilisation is deactivated.
What can be the cause, or what do I have to adjust to eliminate this behavior?
Dirk
PostPosted: Mon 24. Jun 2019 20:24:01
Did you check your flight log to see if there was any error messages? The other matter is did you wait for the Spirit FBL to fully initialize before spooling up and taking flight as this can often lead un-precise stability flight.
I have had this occur, and found that leaving the heli on a level take off point for about 30 seconds after initialization solved the matter. I hope it is as simple as that and you can resume enjoying the hobby.
Regards,
Kevin
Blade 230 S / 230 S NF / 450X / 500X / 550X ~ Trex 470LM ~ OXY 3-285 / OXY 4-325 / OXY 4 MAX ~ Spektrum DX9 BE / DX6 Gen 2 ~ Spirit FBL
_______________________________________________
Team OXY Helicopter - Lynx Heli Innovations Field Rep
PostPosted: Tue 02. Jul 2019 8:17:14
the problem could be in the mechanical setup of the servos and rotor head.
I recommend to tick Servos/Subtrim (tuning) menu.
Then verify that all servo arms are in the center position as close as possible.
At the same time swashplate must be perfectly leveled - Cyclic Leveler should tell you.
And lastly at the same time there must be 0° between main blades.
If all three things are correct, then it should not change direction at all.
Another reason could be if model is initialized on a bumpy surface which was not horizontal. Or if model was inclined for a prolonged time during pre-flight check. In this case waiting few more seconds before starting the motor and take off can help.
Users browsing this forum: No registered users and 73 guests
