It is currently Mon 25. Nov 2024 5:34:57
[ 4 posts ] |
jaffrie
Posted: Sat 22. Jun 2019 14:44:35 |
Hi Guy, Need some advice. Been awhile since I last did a new build. Completed set-up with Jeti Tx & Spirit Pro on Sab Havok 280. During cyclic ring set up servos was moving pretty fast so everything work ok but after completed set up & re power up the heli cyclic servos are moving at about half the speed. Guess I must have miss something, would appreciate some help. Tx swash set to mechanical, Rx 3 connected via Ex Bus on E2 .
Thanks in advance
jaffrie
Posted: Sun 23. Jun 2019 9:46:46 |
jaffrie
Posted: Sun 23. Jun 2019 16:37:31 |
Problem discovered & solved
Posted: Mon 24. Jun 2019 7:29:34 |
The behavior you are describing is very normal and everything is correct.
It should not move fast actually since it is not flybar. With no model response to a commands the behavior is just different than in the air. It is important how it feels in the flight not on the bench. Depending on this you should make an adjustments.
[ 4 posts ] |
Users browsing this forum: No registered users and 52 guests |
