jjuk wrote:
Can you share with me your HW setting that you used? Are you using Gov Elf or Gov store? I couldn't figure out what the difference was?
After some reading I think you're configuring things properly so I'm not sure why it doesn't work for you..
The HW settings - you mean for FBL or HW governoer?
For HW governor, I just use "Gov Store" mode, calibrate the ESC for throttle range, then standardize the RPM for the first time. Auto rotation time is set to 25 sec. Work fine.
I have 2 switches:
- one "throttle hold" sets throttle to fixed "-25%" - this stops the motor, but allows for fast bailout
- additionally I have a momentary switch (I use T5 or T6 somehow - one of additional trims on Horus) which sets throttle to -100%. This forces ESC to spool-up slowly without having to wait 25 seconds. I use it if I land, TH and then want to spool-up and takeoff again for some reason.
For FBL governor, switch setup was similar except of
- using "-75%" instead of "-25" on TH switch
- ESC mode set to "Heli linear"
- Spirit configured as described earlier.
As I said I use HW governor, cannot get Spirit to work properly.
Are you trying to setup HW or Spirit governor now?
