It is currently Mon 25. Nov 2024 4:58:04
PostPosted: Wed 29. May 2019 8:48:44
Hi!
I need you help again.
At the moment I am using the Hobbywing 25v4 esc and its internal governor with uspirit on the oxy 2.
How can I change Head Speeds? I have a switch assigned for bank switching. Is head Speed chaning possible to do with the switch without using Spirits Governor? Or should I use the spirits gov ?
TOm
PostPosted: Wed 29. May 2019 12:10:35
I am not sure if I understand the question. But you can change Head speed as always. Spirit has no influence on the HobbyWing Governor.
Just change throttle curve in your radio. That is the way how you are changing headspeed. Same apply when Spirit Governor is used.
Users browsing this forum: Bing [Bot] and 63 guests
