It is currently Mon 25. Nov 2024 6:39:51
PostPosted: Thu 11. Apr 2019 5:55:57
hi,
i have a issue with my Telemtry output on my Spektrum DX8G2, with airware 2.01. ESC Kontonik jive Pro120 v.1.14. Spirit Pro v2.6.1
Voltage 378 V RPM 47,780. Throttle 50% is korrekt. In Spirit i set ESC Telemtry to "Kontronik & Jive Pro", and Motor settings in Spirit Software.
I use the Spektrum and ESC kabel from your Shop, and SPM4649T + 2 Spektrum SAT.
Even the motor is turnt off, there is laready showing a RPM.
I missed to save my old Firmware for my DX8G2, so i cant flash back to test the old Version. :oops:
Thank for your great job, in the Forum !!
PostPosted: Thu 11. Apr 2019 7:16:29
very likely you are using wrong cable or wrong ESC telemetry settings. Did you read the ESC telemetry guide?
What ESC cable you are using? There are two cables and two ESC telemetries for this ESC.
PostPosted: Thu 11. Apr 2019 7:29:28
Thanks for quik reply ..
yes i was reading the manual, and i am using the Telem KONTRONIK cable from your shop.
ESC Telemtry settings is set to "Jive" showen in the Jeti integration.
But i will check it today.
PostPosted: Thu 11. Apr 2019 7:31:53
You are welcome.
The ESC telemetry must be configured to : Kontronik Kosmik & Jive Pro in this case.
PostPosted: Thu 11. Apr 2019 7:33:45
it is set to Kontronik Kosmik & Jive Pro as you wrote.
but i will check thanks ....
PostPosted: Thu 11. Apr 2019 7:36:28
Also make sure that the single wire connector from the Kontronik telemetry cable is connected at the PIT pin. This is very important.
PostPosted: Thu 11. Apr 2019 7:47:15
ok to PIT ?
PostPosted: Thu 11. Apr 2019 7:49:20
Sorry, the ELE pin as displayed at the photo :) The PIT pin is used for Governor.
PostPosted: Thu 11. Apr 2019 15:33:52
if i plug in my R² PUFFER to AUX2 i have the Problem, now i disconnect my Puffer and everything seems to be alright.
The only thing is when i got to 80% Throttle the RPM shows less then at 50%
Could the R² PUFFER be the Problem ?
P.S. sry for my English .....
