It is currently Mon 25. Nov 2024 7:20:30
PostPosted: Sat 23. Mar 2019 22:44:17
Hi here this my current setup
Spirit Pro
ele/pit/ail.....Rpm wire from esc and signal wire from jeti intergration cable (for telemetry)
RUD........Jeti Intergration cable
AUX 1 .........Throttle wire from ESC
Aux 2 ..........BEC from ESC
CH4................servo
CH3................servo
CH2................servo
CH1................servo
Ch0................Ultraguard
SyS................empty
Primary Sat port....Jeti Cable (for Telemetry)
Sat Port 2..........DSMX Sat
My question, am i able to connect more sats as this is on a goblin 700 and i dont trust the SPM4649T with just 1 sat. I have the spektrum multi adapter but there are no more ports left to plug it into on the spirit, can i use a y cable somewhere? if so how do i connect it?
Many Thanks
Jay
PostPosted: Mon 25. Mar 2019 4:15:13
If you are willing to forego TX Integration (which is possible with the 4649T) you should consider getting an AR8010T. It comes with a Sat and you can add two more. You can do all the telemetry through the AR8010T. You would use the SRXL connection scheme. An AR8010T plus a second sat costs about the same as an spm4649T plus two Sats. So cost is not a factor.
PostPosted: Mon 25. Mar 2019 14:31:44
Correct me if im wrong but I believe the only way to get Telemetry using an AR8010T is to use Spektrum external sensors. Have you gotten Telemetry with the AR8010T as with the 4649T ?
PostPosted: Mon 25. Mar 2019 15:49:47
Without wanting to sound ungrateful can anyone out there actually answer my question?
Cheers
Jay
PostPosted: Mon 25. Mar 2019 16:33:04
Cheers
Jay
If I remember correctly,when I was using the red spirit fbl,Tomas said I could use the Y cable and the spektrum single adapter sold at the Eshop and share the RUD port.
The sat has to be bind first using the regular method before moving it to the RUD port.
I will see if I can find the thread and link it here.
Hope this helps.
Sent from my SM-N950W using Tapatalk
PostPosted: Mon 25. Mar 2019 18:09:11
Thanks rufas that's most helpful.
PostPosted: Mon 25. Mar 2019 21:16:04
Spektrum Multi Adapter can't be used for 2 satellites with SPM4649T since it is already acting as a second satellite.
So you can use just one port from the adapter to connect one satellite.
This mean that Spektrum Adapter v2 is enough, but Spektrum Multi Adapter can be used just for 50% - just with disconnected single lead.
Y-cable can be used at the RUD port for this purpose.
