It is currently Mon 25. Nov 2024 1:40:53
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
PostPosted: Tue 19. Mar 2019 15:05:22
please redownload the firmware from same URL and try it again. I believe it will work now.
PostPosted: Tue 19. Mar 2019 16:12:43
Hello Tomáš,
new try with new download, but no changes to former behavior - led out and no lua function.
Regards,
Toni
PostPosted: Tue 19. Mar 2019 18:41:01
ZeXx86 wrote:
FrSky replied today that they are very busy but will give us a proper reply soon.
In the meantime we have prepared workaround, hopefully this firmware will help:
http://spirit-system.com/dl/fw/spirit-fw-2.6.2.4df
It is identical with 2.6.1 except small change in the firmware for these FrSky receivers.
It works! :D
Thanks Tomas!
PostPosted: Tue 19. Mar 2019 20:39:04
Here is a video of Rx8r Pro working properly with Spirit integration after updating Spirit with the new firmware that Tomas gave
https://youtu.be/6vSLM5BzdEE
PostPosted: Wed 20. Mar 2019 10:18:52
after a new download this morning it works properly here with me too - maybe I was too fast with downloading the second version yesterday and got first again.
Many thanks to Tomáš!
Regards,
Toni
PostPosted: Thu 21. Mar 2019 1:30:05
I got the chance to try it myself this evening and can confirm that it works fine here. Thanks for that Tomas. I await with interest to see what FrSky come back with.
Cheers
Chris
PostPosted: Thu 24. Oct 2019 23:26:16
Hi, Tomas, this now doesn't work with the new Spirit 2. It is exactly the same behaviour, that is if you start the LUA first then power on the Spirit 2 then it works. If you just power on the Spirit 2 unit before starting the integration LUA on the Tx then nothing works and the Spirit 2 LED light turns off. Exact same behaviour as happened with the old Spirit units and FrSky Rx8R pro before you fixed it. I thought it was something to do with the latest firmware version 2.6.4 but it isn't as I also have a Spirit Pro that I updated to version 2.6.4 and telemetry/integration works fine on that with the same FrSky Rx8R Pro receiver (I uploaded the firmware that you issued to fix it on the old Spirits a while back, maybe the Spirit 2 needs something like that?). FrSky didn't have a clue how to fix this but you fixed it on the old Spirit units. So I would be grateful if you could with this new Spirit 2 unit. Thanks.
PostPosted: Fri 15. Nov 2019 13:14:29
the problem was resolved definitively. Fix will be available in the update next week.
PostPosted: Fri 15. Nov 2019 16:11:17
Thanks Tomas. I have been using a FrSky R-xsr for now in redundancy configuration with a Frsky xm+, just to get integration, on the 550X but I will put the Rx8R Pro back on once the update is available. I trust the Rx8r pro more on a large heli.
Users browsing this forum: No registered users and 37 guests
