It is currently Mon 25. Nov 2024 5:22:18
[ 7 posts ] |
Bischi
Posted: Mon 18. Feb 2019 8:22:40 |
Hi Support
I hope anybody can help me. I dont see the telemetry Datas on the DS16.
My System:
- Jeti DS16 V4.28 - REX 3 V1.12 - Cool Kosmik V4.15 - Spirit Pro V2.6.1 - Jeti integration and ESC Cable V2
Settings in the Kosmik: 14 and 9.71:1 Settings in the Spirit: Kosmik and 7
Integration works well, but the telemetrie works nothing.
I dont know what is the mistake. Any ideas?
Best regards Michi
Posted: Mon 18. Feb 2019 8:28:12 |
maybe you are not using correct port in the Kosmik for telemetry. Is the Telemetry configured for TelMe Telemetry? Not old Kontronik Telemetry.
Bischi
Posted: Mon 18. Feb 2019 19:33:59 |
Hi Thomas
I think the telemetry can only be configured at the Kosmik 250.
I use a cool kosmik 200 and I can not adjust anything, right?
If I use the old V1 cable I have telemetry on the DS16, but with the V2 cable I have no telemetry on the display.
Best regards
Michi
roxxter78
Posted: Mon 18. Feb 2019 21:17:21 |
You must connecting the v2 cable to the middle port of Kosmik. Then it works fine.
Posted: Mon 18. Feb 2019 22:17:43 |
Bischi
Posted: Tue 19. Feb 2019 19:42:15 |
Hi Thomas
Thanks for your help, now it works.
Unfortunately have not seen the instructions for the V2 cable, excuse me.
One last question if the setup is correct?
Setup in the Kosmik: Motor Poles 14, Gear Ratio 9.71:1
Setup in the Spirit : i Motor Shunt 100%, Sensing Divider 7, Gear Ratio 9.71
Best regards
Michi
Posted: Wed 20. Feb 2019 10:37:58 |
settings in the ESC should be at default values. Only changes in the Spirit unit is required. Otherwise Gear Ratio will be wrong.
[ 7 posts ] |
Users browsing this forum: Storchy and 7 guests |
