It is currently Sun 24. Nov 2024 12:29:34
PostPosted: Sat 26. Jan 2019 13:13:12
Hi
I used a Spirit Pro unit with a Frsky X8R receiver and a Hobbywing 130A v4 Opto ESC. Telemetry and integration was working perfectly.
I switched to Jeti DS16 using a REX3 receiver. I connected everything according to the Jeti Integration wiki page. I can configure the Spirit unit from my TX. But i never receive any telemetry values from the ESC. All the sensors are discovered but i never get any value.
I'm not able to find the mistake i made. Do you have any ideas what could went wrong?
oli
PostPosted: Sun 27. Jan 2019 20:37:24
probably you are in the Configuration mode - the Status LED of the uni tis flashing.
You have to close the integration menu if it was entered previously.
PostPosted: Sat 02. Feb 2019 19:18:39
No im not in configuration mode. I double checked that.
PostPosted: Sun 03. Feb 2019 14:40:45
found the mistake :roll:
i also turned the spirit unit 180° when i switched to jeti receiver. so the telemetry cable from the hobbywing esc was not in the primary satelite port :(. turned it back and telemetry is working properly :D
PostPosted: Mon 04. Feb 2019 8:24:59
Very well :) Sometimes these issues are happening.
Users browsing this forum: Bing [Bot] and 66 guests
