It is currently Sun 24. Nov 2024 17:27:29
[ 3 posts ] |
Yaw Pedal
Posted: Sat 02. Feb 2019 13:57:01 |
Apologies if this has been answered already - my search through the forum didn't turn anything up.
I have Jeti integration and telemetry from the Castle Edge HV working fine, and also want to use the integrated Spirit gov.
Does the white wire from the Castle still need to be plugged into the middle pin of the ELE/PIT/AIL plug or does the Spirit governor just use the rpm value sent through the telemetry signal? I assume the latter and that I wouldn't need to use the white wire from the Castle, but no harm in asking before I go splitting plugs.
Thanks!
Posted: Sat 02. Feb 2019 15:15:16 |
for Spirit Governor you have to connect white wire at the PIT pin. Telemetry cable is unfortunately not enough - it is too slow for governor operation.
Yaw Pedal
Posted: Sun 03. Feb 2019 5:27:31 |
Thank you Tomas, fantastic support as always!
[ 3 posts ] |
Users browsing this forum: No registered users and 72 guests |
