It is currently Mon 25. Nov 2024 3:03:42
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
PostPosted: Fri 01. Feb 2019 15:27:52
It looks like it is the receivers wifh redundancy bus that are affected by this then. They might be running a slightly different firmware and that might be the reason I think.
Sent from my SM-G950F using Tapatalk
PostPosted: Sat 02. Feb 2019 15:17:50
Sadly we have still not received any reply from FrSky regarding this issue.
PostPosted: Sat 02. Feb 2019 17:23:14
Tomas, I will send them a message on RcGroups and I will link them here. I think they have an active representative on RcGroups.
PostPosted: Sun 03. Feb 2019 10:50:51
Hi Tomas, a Frsky rep replied on RcGroups. He said they have noticed the problem and will give a reply as soon as possible https://www.rcgroups.com/forums/showthr ... st41081627
PostPosted: Mon 04. Feb 2019 8:35:14
Thank you for the message.
We will urge the issue directly in FrSky once again.
PostPosted: Fri 15. Feb 2019 10:10:25
Today FrSky received our unit for testing and in no time they have managed to perform the tests.
And results - It is working perfectly with RX8R receiver and Taranis Q X7.
They have sent video from the testing and it just works.
They were using OpenTX 2.2.3. Next week they will be performing tests with X12s. Can you confirm that it does not work with this version for you?
PostPosted: Fri 15. Feb 2019 11:02:57
I will try it this evening or tomorrow morning with the receivers I have. I think I was running Open TX 2.2.3 when I tried it before, but will make sure. I'll also make sure I have the latest receiver firmware.
Using Horus X10.
PostPosted: Fri 15. Feb 2019 11:06:47
Hello Tomáš,
I have done a quick test using my 12x with OpenTx 2.2.3 and I cannot see any difference in behavior than before.
Lua scrips only work when starting them first and then power up the heli.
Regards,
Toni
PostPosted: Fri 15. Feb 2019 11:11:46
Addition:
When I start Lua first, Spirit LED keeps on blinking even if I escape the scrips screens.
PostPosted: Fri 15. Feb 2019 11:52:06
Tomas, it only works if you start the lua script first then connect the integration cable then power on the FBL. If you, first, power on the FBL with the integration cable connected to the rx8r pro, the red LED on the Spirit Pro just keeps on blinking and when you start the lua on the Qx7s nothing loads on the lua script fields. The LED on the Spirit Pro will stay on blinking until you disconnect the integration cable.
I will make a video of the issue when I get home later today. For now I fly the heli with the integration cable disconnected as if you leave it connected, the LED on the Spirit Pro just continues blinking after you power the heli on. Even if you exit the lua script, the LED on the Spirit just keeps on blinking and continues to blink. The only way to stop it blinking is to power it off, disconnect the integration cable then power on with the integration cable disconnected.
Users browsing this forum: No registered users and 89 guests
