It is currently Mon 25. Nov 2024 4:01:48
PostPosted: Tue 08. Jan 2019 10:46:34
Hello!
I want to update my Spirit Pro unit to Version 2.6.1.
As I've understood I can't use my Telem KONTRONIK v1 cable any longer after the update, so I need the v2 version.
My problem is that this cable is only 22cm long but I need at least 35cm.
I searched for an JST-extension but I get offered Mini oder Micro-JST, molex cables and so on. There are so many kinds of jst plugs that I don't know which one would be the right one. Also I don't like extensions at all.
So I wanted to ask if there's a possibility to order a Telem KONTRONIK v2 cable with 35cm length?
Otherwise I would have to use my soldering iron ...
Greetings,
Thomas
PostPosted: Tue 08. Jan 2019 10:58:32
you can still use Telem KONTRONIK v1 without any change.
So you do not have to order v2 or make any modification :)
PostPosted: Tue 08. Jan 2019 13:09:41
Ah, so I misunderstood this.
That's great news, thank you! :)
PostPosted: Tue 08. Jan 2019 14:54:56
In any way, you can easily modify your current cable so that it will work as v2. You will need the JST-Servo adaptor cable.
