It is currently Mon 25. Nov 2024 3:25:21
PostPosted: Thu 20. Dec 2018 10:27:09
hi another issue im having with frsky integration is when i go into integration menu to change setting usually when i click save, the helicopter locks out.if its one of my nitros it will put throttle servo back to zero throttle,so engine cuts out.if its an electric heli,i can go out of and back into menu and it will unlock again and be flyable.what causes this?is there a fix?
PostPosted: Sun 30. Dec 2018 5:44:28
bump.
PostPosted: Fri 04. Jan 2019 0:08:36
Bump
PostPosted: Fri 04. Jan 2019 8:01:23
unfortunately we have no details from you and nobody else reported the issue. So it is very hard to help you.
Did you updated firmware and Lua scripts to the latest version?
Did you tried to disconnect everything that is not necessary?
PostPosted: Fri 04. Jan 2019 11:39:28
Thank you for reply. Sorry I have not provided much info. I'm away till tomorrow, I'll check firmware and lua. I do have an rpm/temp sensor hub connected using just the temp sensor, I'll disconnect that and see what happens. I'll report back with more info. Thank you.
Users browsing this forum: Bing [Bot] and 11 guests
