It is currently Mon 25. Nov 2024 2:50:40
[ 2 posts ] |
Posted: Tue 25. Dec 2018 14:02:48 |
Joined: Wed 21. Dec 2016 15:13:38 Posts: 568 Location: Germany
Hello, I have mentioned some changes in the software fom 2.52 to 2.60 - The first thing was the same as stewartgrant37 said. The gyrogain can not change to in Normal Mode when you set any Stabi/Function. Only if the Stabi/Function is deactivated or like in the table "Stabilisation (Scale)" is used (with and without headlocking) - The other thing I mentioned is if you have set at first no bank switching and proceed the setup and set the pitch range you want eg. 12° and then set later the bank switching you have not the same pitch in the bank 1 or 2 - I think that was under 2.52 not - I wondered at first that I have another pitchrage in bank 1 or 2 than in bank 0 ?! Therefore I looked at value at the pitch and here I saw an value of 64 - The value at bank 0 was 180 (12,5°) ! My question is is that so wanted that you now can change the pitchrange directly in the bankes ? I am not realy sure if that was also necessary in 2.52 - My preprogrammed Goblin 500 Sport (last year, Spirit Pro 2.52) I think it was not necessary to change pitchranges in the other banks - Has anyone an idea ? Tomas may be you read this, what do you think about ?
Best regards Matthias
Posted: Tue 25. Dec 2018 18:51:17 |
both mentioned features are completely same with 2.5.2.
When bank 1 and 2 is completely unset then pitch range is equal to bank 0.
You can check changelog for 2.6.0 releasr to see what is different.
[ 2 posts ] |
Users browsing this forum: Bing [Bot] and 86 guests |
