It is currently Mon 25. Nov 2024 2:35:09
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri 07. Dec 2018 21:46:03
Can I use another port than the rud port? I think I’ll buy a multi adapter instead..
PostPosted: Sat 08. Dec 2018 15:54:24
if you want to test the rud port, then you have to connect something to rud port
btw if rud port is broken then the multi adapter will not work
as is connected to rud port too
PostPosted: Sat 08. Dec 2018 18:28:30
Of cause, but as of right now it’s the cheapest test for me and I wouldn’t mind to own the multi adapter anyways..
If the multi adapter doesn’t work, then the rud port is probably broken and I’ll need to send the unit for repair. Is there some sort and guarantee on it? Its not a long time since I purchased it.. and I’ve only used it one single time..
I’ll probably buy a second one anyways because that geolink feature is so insanely cool.. especially the altitude limit...
Br, Peter
Users browsing this forum: Bing [Bot] and 65 guests
