It is currently Mon 25. Nov 2024 2:48:44
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed 05. Dec 2018 20:17:59
I still cannot get this working! In fact I think I may have been misinformed.
I purchased the following unit:
http://store.spirit-system.com/en/acces ... er-v2.html
Plug it into the rud port after binding my sats, and nothing...
I have tried everything and I just doesn’t work...
I think I need to buy the multi adapter instead..
PostPosted: Thu 06. Dec 2018 1:23:47
in fact if you look in the manual
http://manual.spirit-system.com/index.p ... _SATELLITE
seem the "single" spektrum adapter is only supported in spirit, not in spirit pro
but im not 100% sure of that
PostPosted: Thu 06. Dec 2018 12:27:31
is the satellite bound? If not, then it will not work.
PostPosted: Thu 06. Dec 2018 12:35:43
Yes of cause I have bound them!!! It’s not working and I agree I don’t think this is supported for the Spirit Pro! I need the multi adapter for it to work!
PostPosted: Thu 06. Dec 2018 13:50:54
You do not need the Spektrum Multi Adapter.
Can you tell me how you are verifying that it is working?
Am I right that the connection is working properly if Spektrum satellite is connected in the Secondary port? (Native port in the Spirit Pro, not one that is used for GeoLink).
But if you unplug this satellite there is no connection, right?
PostPosted: Fri 07. Dec 2018 8:50:29
Here is what I do:
1. Plug both satalites into Spirit Pro micro-jst plugs (naitive) in this case they are DSM2
2. I bind the satalites using the bind plug, and both satalites are now showing a constant light.
3. I remove the bind plug, restart the system to test everything is working.
4. I turn the power off, remove the secondary satalites and plug it into the Spirit single adapter. I then plug the adapter into the rudder port.
5. I turn the power on. The primary satellite connect as usual, but the satellite on the adapter is completely dead. It doesn’t show any light, not even a slight blink. It’s just completely dead
Kind Regards,
Peter
PostPosted: Fri 07. Dec 2018 14:49:27
Is there a way I can test my rud port? Maybe its broken..
PostPosted: Fri 07. Dec 2018 17:47:06
sure ... connect a standard receiver (not single line)
then check in the settings program if rudder indicator move when you move rudder stick
PostPosted: Fri 07. Dec 2018 20:04:49
What do you mean with standard receiver? I only have satalites so I don’t think I have a “standard receiver”..
Can I connect a servo instead?
PostPosted: Fri 07. Dec 2018 21:01:06
nope ... RUD is input port
standard i mean a receiver that carry all output channels separately
you have a spektrum then you can buy on hobbyking a very cheap spektrum compatible receiver for about 18-20€
Users browsing this forum: No registered users and 83 guests
