Dear Mr.Thomas,
Sorry to keep the subject alive. Regrading your advise to Mr.Eugen as below:
We have prepared special firmware where pressure influence has no impact on the performance of the Altitude Limit. It look like when GeoLink mounting holder and tail boom does not allow free air circulation it is causing problems. Air is then reflected and pressure is not changing accordingly.
So it could be solved mechanically but with the firmware it should work in any case.
If anybody is interested you can contact me.1. Please clarify the Geolink mounting method blocking the free air circulation issue. He mount the Geolink on a flat surface and the bracket seems to cover the whole bottom surface of the Geolink module:
Is this the problem? Is it necessary to have some portion of the bottom area expose to the free air as below picture:
I am asking these questions because on my new Geolink mount design, the bottom of the module is completely covered when assembled. Only the four sides and top of the module is expose to the air. Is that good enough?
2. I would like to try the upgraded firmware too. Any chance that I can have it?
Best regards,
Amal
