It is currently Mon 25. Nov 2024 2:53:34
Post new topic Reply to topic  [ 14 posts ]  Go to page Previous  1, 2
PostPosted: Tue 20. Nov 2018 8:59:11
For Wifi-Link you can find it in the Throttle/Governor configuration.
If you will change Gear Ratio it can show you any RPM. But the question is why it does not match now.
As a temporary fix you can set the ratio so that it will simply match real RPM. Then all should be good.
PostPosted: Tue 20. Nov 2018 22:27:33
Will do. Can I support you to identify the issue somehow?
PostPosted: Wed 21. Nov 2018 15:49:38
The only thing that could help is to have your Jive ESC here, because with our Jive ESC it is working properly for quite long time.
Kontronik Jive telemetry protocol is not public, so we can only find a details with trial and error. Probably your ESC has a different version.
We are in contact with Kontronik to check what we could do.
PostPosted: Wed 28. Nov 2018 20:42:13
a Jlog connected works fine without problems. Perhaps it is more or less linked to Sbus2 connection, as I cannot check in the application the RPM from the ESC.
Has to set it now to 5 poles with gear ratio of 3,5 which matches perfectly.
Cheers,
Nils
Users browsing this forum: Bing [Bot] and 89 guests
