It is currently Fri 22. Nov 2024 12:56:34
PostPosted: Sat 03. Nov 2018 18:14:38
My Spirit Pro does not detect the Sbus2 receiver 7006SB on rather every 4th bootup. It does not show any warning in the log and also show the "ok" pitch movement. But in the configuration software no movements of the sticks are detected and also the telemetry is not transmitted. The Jive connected to the receiver directly works fine. There was also one case the spirit give full rudder and pos. pitch.
Any ideas about that?
Configuration:
Jive 60HV
Connected for telemetry
Sbus2 Receiver connected with changed Frsky cable (extended to 30cm length)
Regards,
Nils
PostPosted: Thu 08. Nov 2018 15:20:22
Please check your private messages.
I have sent you a possible solution.
PostPosted: Wed 14. Nov 2018 16:53:36
Solved in newer firmware. Thx
Users browsing this forum: No registered users and 24 guests
