It is currently Mon 25. Nov 2024 0:44:06
PostPosted: Fri 02. Nov 2018 11:56:27
Hi team Spirit / everyone
Could someone please make a video on setting up the geolink, it shouldn't take long and I'm sure it would be good for sales as well.
Kind Regards,
Peter
PostPosted: Fri 02. Nov 2018 22:16:43
Am I the only one who finds this complicated to setup?
PostPosted: Fri 02. Nov 2018 23:45:06
What do you mean by settings ? The configuration of the Geolink, or the calibration?
Erik
PostPosted: Sat 03. Nov 2018 0:26:40
It shouldn't be complicated,bud.
Watch the video posted about the calibration,which was posted by I think a gentleman called Frank,once hooked up,everything is straight forward from the spirit software and the manual.
Trust me,if I can do it,you can too.Also,maybe post exactly what you're having problems with and folks here are as good as it gets,they will help.
Sent from my SM-N950W using Tapatalk
PostPosted: Sat 03. Nov 2018 9:44:21
Is this the video?
https://www.youtube.com/watch?v=skH0u2yV6_M
I not that far yet, right now I'm just trying to figure out how to activate all the different functions.
I'll look at it again on monday, and I didn't spend much time I'll admit that its just so much easier to follow a video instruction for me.
Br, Peter
PostPosted: Sat 03. Nov 2018 15:34:39
^^^^^....Yes,that's the video.
To activate any function,you have to go through this calibration process first,mount the geolink,hook everything up as per the manual,open the spirit software and that's where you can active the various functions you want and assign them to channels.
It's all in the software.
PostPosted: Tue 06. Nov 2018 23:56:32
So I spent my entire evening on setting this up and I still can’t figure out how to get all the features programmed on my DX8, I would really very much recommend to make a video sure you would avoid a gazzilion question on this forum..
Side question - anyone knows that this banks is?
Br, Peter
PostPosted: Wed 07. Nov 2018 8:45:48
generally I do not recommend to use all the features. You should decide in which you are interested in and if it is easier for you, just enable one and try it. Then you can try all one by one and find which suits well your needs.
If you have 8 channels available you can just turn one feature in the General/GeoLink/Aid tab. Then go to General/Channels and assign the same feature to a free channel by selecting the feature in the drop down list - for example F: GeoLink Position Hold and Channel 7 or 8.
Then by changing switch position on your radio you should see some activity in the window. So that you can engage the feature at any time.
Unfortunately since each radio is different there can't be any guide that will tell you how to set everything exactly. But we can create few examples that could be helpful.
PostPosted: Wed 07. Nov 2018 9:46:28
Hi admin
I think it would help with a couple of videos made with a smartphone or similar.
At least for myself, I think the more feature I can have the more fun it is. I would even be ready to remove my gyro gain to make room for an additional channel if possible, just because those other features seem so great.
Br, Peter
Users browsing this forum: No registered users and 73 guests
