It is currently Mon 25. Nov 2024 0:20:27
[ 3 posts ] |
augur
Posted: Thu 01. Nov 2018 14:51:01 |
is there a way with WLan adapter to see the actual parameters set by real-time tuning by transmitter? As I read in the manual the mapping between stick value -100% -> lowest possible parameter value, +100% is highest possible parameter value. So for collective gain starting at 20 is -100% mapped to it? To get 60 gain I have to set stick to 0%?
Cheers, Nils
Posted: Thu 01. Nov 2018 19:15:11 |
yes, you are right.
You can connect Spirit Settings for PC to your Wifi-Link and check the values.
Or you can just close the Spirit Settings in the Wifi-Link web app, set value with a knob in your radio and then you can open Spirit Settings again. After this you will see value that was configured by assigned channel.
augur
Posted: Thu 01. Nov 2018 23:15:04 |
thanks for the hint with restarting the app. This does work well (btw. the greyed out rudder gain is no updated like the other parameters). Would be nice to get the values instantly to avoid missconfiguration.
The native PC app does not stop its process after configuration of the IP. Have to stop it manually. Not it does not came up and hangs with the splash screen. Perhaps you can add a list to configure different IPs and also hostnames. I added the spirit to my local network so this would be easier if you owns more than one unit.
Cheers, Nils
[ 3 posts ] |
Users browsing this forum: No registered users and 81 guests |
