It is currently Mon 25. Nov 2024 2:59:18
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu 18. Oct 2018 21:35:53
It is unfortunately possible that the mounting of the module does not allow air to flow freely around. This then create backward pressure so that it sense much higher height than the real one.
It is only guess but we can check it from the GeoLink flight log. It would be good to have log when your model is in the knife edge maneuver. It is only important to find which time of the log it is.
This could help with finding where the problem really is.
We are just working on an alternative solution where air flow will not matter that much in the upcoming firmware update. So that mounting will have minor role.
So if we will confirm through the log that it is due to mounting it could solve the problem.
PostPosted: Fri 19. Oct 2018 7:08:58
Good morning
can you give me an email address and I will send you the log file of the geolink where I do several knife edge drops without rescue kicking in.
the forum does not let me attach 4dl files
Erik
PostPosted: Fri 19. Oct 2018 10:46:13
thank you, email is: tomasj@spirit-system.com
Now it is possible to attach 4dl files here but you can send them to email.
PostPosted: Fri 19. Oct 2018 10:50:14
thanks, are send by email
PostPosted: Fri 19. Oct 2018 15:37:02
Here are the logs in the forum
Knife-edge-test-1.4dl [3.82 KiB]
Downloaded 72 times
spirit-log-2018-10-16-163658-f5.pdf [75.19 KiB]
Downloaded 78 times
PostPosted: Fri 19. Oct 2018 16:32:44
I can confirm that this problem exists. I tested it today with my T-Tex 550X and could repoduce it several times. Picture of my GPS mount location is attached.
BR Eugen
PostPosted: Tue 23. Oct 2018 0:07:22
I would like to add my name to the list of people with this problem. I finally got to do some more flying and more testing on the GeoLink. The altitude limit works fine every time as long as the skids are down (did not try it blades down). I tried it with the Heli coming down at an angle and it does not rescue. I tried this at least four times and all four times it would not rescue. Mine is mounted on a Goblin 500 Sport.
PostPosted: Tue 23. Oct 2018 7:19:09
Thank you for the details.
We are working on the solution.
PostPosted: Tue 23. Oct 2018 17:05:19
Dear Mr.Eugen
Is your GeoLink mount made of plastic + aluminum + steel parts?
Regards,
Amal
PostPosted: Wed 24. Oct 2018 5:19:42
Dear Amal,
My GeoLink mount is made of an aluminium clamp with a 40 x 40mm carbon fiber plate glued on it. As of today I would use the GeoLink mount Spirit is selling, but it was not available when I bought the Spirit Pro with GeoLink.
BR Eugen
Users browsing this forum: No registered users and 81 guests
