It is currently Mon 25. Nov 2024 1:50:28
[ 4 posts ] |
Franky13
Posted: Wed 26. Sep 2018 17:22:49 |
Hi Tomas!
Please explain to me why the 6 degree geometry should be set to 4.5 on TDF. What is better at 4.5 Geometry, what are the positive effects of the change in TDF? Or can adjust other parameters to get the same effect?
Thanks for answer!
Greeting Frank
Posted: Thu 27. Sep 2018 8:04:17 |
TDF has not standard geometry and because Geometry 6° is counting with standard geometry it require different configuration for linear servo travel. If value is too high then you will get unwanted oscillations and problems with elevator.
No, you can't achieve same settings with other parameters.
mb-1953
Posted: Thu 27. Sep 2018 12:30:57 |
Would this also apply to the tdr2, which also uses linear linkage.
Posted: Sun 30. Sep 2018 18:01:26 |
Yes
[ 4 posts ] |
Users browsing this forum: Bing [Bot] and 41 guests |
