It is currently Sun 24. Nov 2024 22:45:48
PostPosted: Tue 04. Sep 2018 1:54:51
Spirit 2.5.1 using original BT adaptor with android app seems has problems:
I have updated and flown all 3 of my units on 2.5.1, but while at the field using the BT connection and phone app, many B0 (bank 0) functions are grayed out and not accessible...
No access to the General Channels menu.
Same no access to:
Rudder endpoint
Servo Menu - all items Type, Rev, Sub-Trim, Trav Corr
Limit menu - Cyclic Ring, Rudder end point
(interestingly Collective Pitch is working here though)
The above listing is from a uSpirit, but a Pro seems to have the same issues.
Thoughts?
PostPosted: Tue 04. Sep 2018 7:12:35
Yes, you have enabled the Basic mode - this is accessible in the Connection menu.
Once you will disable it, all will work again.
This is feature to protect you from changes that could lead to a crash but can be enabled/disabled anytime.
PostPosted: Wed 05. Sep 2018 3:55:39
Thanks. That solved it.
PostPosted: Thu 06. Sep 2018 9:23:38
You are welcome!
Users browsing this forum: No registered users and 80 guests
