It is currently Sun 24. Nov 2024 22:41:28
[ 7 posts ] |
Franky13
Posted: Mon 27. Aug 2018 18:14:43 |
Hello! Can someone give me the error message of the spirit when the LED flashes? For me, the LED is flashing slowly!
greeting
Posted: Tue 28. Aug 2018 8:09:15 |
if the Status LED is flashing slowly when the Spirit settings is connected then from version 2.5 it indicate that unit is in configuration mode. This is correct and there is no error.
If it is flashing constantly from the power up, then there is some serious issue unfortunately. Could you describe from when you can see the flashing?
Franky13
Posted: Tue 28. Aug 2018 9:22:03 |
Hi!
When the spirit is connected, it keeps flashing! The Spirit but can be controlled normally with the transmitter, LED is flashing.
Greeting
Posted: Tue 28. Aug 2018 9:35:17 |
Ah, that is interesting.
Do you think you could record a short video of how it is flashing?
When it started to happen for the first time?
Can you disconnect everything that is not required in the unit? Only powering cable is enough.
Franky13
Posted: Tue 28. Aug 2018 9:58:57 |
...if i want to set the spirit in the sender, I get an error message, it keeps blinking.
Franky13
Posted: Tue 28. Aug 2018 10:11:35 |
Sorry, can not upload a video
Posted: Tue 28. Aug 2018 10:19:31 |
So it is only starting from point when you try to enter Jeti integration menu? If yes, then all is correct.
It will do the same when you start Spirit Settings software in your computer.
[ 7 posts ] |
Users browsing this forum: No registered users and 70 guests |
