It is currently Sun 24. Nov 2024 22:38:48
PostPosted: Thu 23. Aug 2018 17:55:50
Hi, should the map in the Geo link system page shows the actual position? And should the map automaticly find the right place?
After setup it shows a map position about 50km away and it is not moving automatically.
PostPosted: Thu 23. Aug 2018 18:18:40
Use the home button your are probably using the isp button.
The isp button is to start you not too far of where your are connected
Envoyé de mon iPhone en utilisant Tapatalk
PostPosted: Sat 25. Aug 2018 18:33:15
Hi all, yes I pushed home button but there is only a black screen. When I push ISP I have a map from a position far away and when I move the chart I come home to my place where the Heli stands. But again when I push home the chart is away and I have a black screen.
Addendum: what are the colours meaning ( the ring at the position has 3 different colours.)
PostPosted: Sun 26. Aug 2018 10:46:13
the map will show you your current position if there is GNSS signal, but it will not get you automatically there.
This is work for upcoming update :)
Users browsing this forum: No registered users and 82 guests
