It is currently Sun 24. Nov 2024 22:45:13
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri 24. Aug 2018 14:22:40
Yes, BIN file for Jeti DS16 that is on your SDCard. It must be always updated to the same version as Spirit firmware.
Spirit firmware is different thing.
Please see JETI integration guide:
http://manual.spirit-system.com/index.p ... reparation
There you can see also warnings that explains what you see.
PostPosted: Fri 24. Aug 2018 14:38:21
ok, the bin file is available in the devices folder
PostPosted: Fri 24. Aug 2018 14:39:02
PostPosted: Fri 24. Aug 2018 14:41:46
Yes, this SPIRIT.bin must be replaced with new Spirit.bin that you can download from our web page from yesterday for version 2.5.1.
Current file is for 2.4.3 if you were not doing any changes there.
PostPosted: Fri 24. Aug 2018 14:48:31
Ok!
Where can I get the spirit bin file?
PostPosted: Fri 24. Aug 2018 15:10:47
in this page:
http://manual.spirit-system.com/index.p ... ntegration
there is this link:
http://spirit-system.com/dl/jeti/Spirit.bin
PostPosted: Fri 24. Aug 2018 15:30:59
Thanks!
PostPosted: Mon 27. Aug 2018 11:04:52
Sorry, it does not work!
I get in the DS16 the message: "Error device not recognized. Spirit bin, Line: 1"
PostPosted: Tue 28. Aug 2018 10:20:37
Your Spirit.bin file is not probably there or is somehow downloaded incorrectly.
You have to download the latest Spirit.bin file and save it in the Devices directory in SDCard of your radio.
Only then it can work correctly.
PostPosted: Tue 28. Aug 2018 13:37:39
Thanks for the answer!
I've downloaded the bin file several times and dropped it into devices via drag and drop.
it does not work for me with version 2.5.1!
I had never had problems with the previous versions before!
I can not explain it!
Users browsing this forum: Bing [Bot] and 74 guests
