It is currently Sun 24. Nov 2024 23:30:28
PostPosted: Mon 20. Aug 2018 10:24:47
hello service team,
some questions about my installtion. HOTT GAM is assigned at spirit.
Spirit setup menue is shown at MZ18 (TX) telemetry menue - that's fine.
Original GAM setup coming from HOTT has some more options to define - for example - setting number of poles. Isn't it needed?
Question above has to be checked into relation to following behavoir. Every value shown at telemetry seems to be half of amount as expected - for example
RPM is shown as 1400 - but that never true ;-)
A is shown as 28 A - but that never true ;-)
and so on.
rest is fine - heli flys perfect .
thanks and br siggi
PostPosted: Mon 20. Aug 2018 13:59:36
are you using the Telem UNI cable connected in the satellite port?
See this page: http://manual.spirit-system.com/index.p ... _Telemetry
PostPosted: Mon 20. Aug 2018 15:02:51
hello,
yes I did as defined at the manual - left side from pins in front.
br siggi
PostPosted: Mon 20. Aug 2018 15:28:42
Great. Is the ESC flashed with the latest firmware?
With older firmware it will not work.
PostPosted: Mon 20. Aug 2018 15:36:29
Yes I did flash it with the latest version - before testing.
Did you have any additional idea to check ?
br siggi
PostPosted: Thu 23. Aug 2018 10:42:58
are the values actually updated in some way?
If they are constantly same, then there is some telemetry connection issue or ESC firmware is really outdated. There is no other option.
Is some other sensor connected there? I recommend to make it as simple as possible.
PostPosted: Mon 27. Aug 2018 10:27:18
hello serviceteam,
it's fixed - I reinstall last update at ESC and removed every additional sensor from system.
it works with proper values.
I'm going to add removed sensors step by step to check impact or not.
thanks and br siggi
Users browsing this forum: No registered users and 19 guests
