It is currently Mon 25. Nov 2024 17:15:00
[ 3 posts ] |
azaz44
Posted: Wed 08. Aug 2018 22:12:20 |
How to match these two? In my case I have a Goblin 570 Sport with Spirit Pro and AccuRc has Goblin 570 Sport too. I would be so happy to habe them fly similar.
Spirit has cyclic and rudder agility expressed as a number, like default 8, while in AccuRc this is expressed as deg/s, with numbers like 500. How to match them? What about flight style? Anybody had some luck trying to get both work similar?
Sent from my SM-N950F using Tapatalk
Posted: Thu 09. Aug 2018 21:30:33 |
It is unfortunately not possible to tell what number correspond to deg/s rotation. But 8 should be close to 250 deg/s, 12 could be already 400 deg/s. But speed is only small portion of the behavior. More important is Cyclic Feed Forward and unfortunately this parameter can't be configured in nearly any simulator. The most simulators are flying as when CFF is at value 1 - 3 so the steering is somehow too smooth and delayed. But I can't comment about AccuRC.
azaz44
Posted: Fri 10. Aug 2018 8:34:07 |
Thanks, these numbers are something to start with.
About Cyclic Feed Forward, "Aggressiveness" of cyclics, how can I understand this? Is this, in some way, a speed how fast the servo is moved to its target, which in turn depends on stick inputs and sensors?
[ 3 posts ] |
Users browsing this forum: No registered users and 0 guests |
